Can B&W Prices be Haggled with?
Discussion in 'Home Cinema Speakers' started by BenW, Nov 1, 2005.
  1. BenW
    BenW
    Jun 3, 2005
    888
    Stansted
    +17
    Just wondering, if i went into a store wanting to buy some 601 S3 would they be able to lower the price (I notice they're the same price everywhere)?
    And if so would it be normal practise to try and get them at a lower price? I say that as in you wouldnt go into currys and try to get a tv cheaper
  2. windfall
    windfall
    Oct 19, 2003
    2,432
    48
    LFC Kop End
    +68
    Best I have had is 10% but that was partly because of regular custom from a dealer in Milton Keynes. You should be able to get something off but not much!
    I decided to buy second hand after that, much better discounts and generally the people that buy that sort of kit look after it.
    Tone
  3. BenW
    BenW
    Jun 3, 2005
    888
    Stansted
    +17
    Thanks Tone, i know people also get discounts when buying other stuff at the same time.
    I'm assuming B&W tell the shop how much they have to price it at? Still, 10% of £250 is £25 which aint too bad!
  4. ChrisNic
    ChrisNic
    May 11, 2003
    2,027
    63
    Thame
    +149
    From my experience the prices are pretty fixed however shops are usually willing to throw in accessories with the speakers (£180 of cables with my 805s's)
    You can only ask.....
  5. rm-lewis
    rm-lewis
    Nov 1, 2005
    36
    Stockport, Cheshire
    Where would you suggest looking for second hand equipment? Is there a specific forum where people would sell, or is it just a case of looking on ebay and local newspapers?
  6. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,286
    Welwyn, Herts
    +943
    B&W speakers (and Kef, for that matter) are less amenable to haggling than pretty much anyone else.
    Nick
  7. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,672
    By all means try,but the best you're likely to get,as with others above,is a few bits of wire,which is about what was offered to me when buying my 805s.....this sort of thing is by no means unusual,as many of the major UK companies do the same,and Linn can be added to the list of non-discounting manufacturers.
  8. j0hn
    j0hn
    May 26, 2005
    1,947
    48
    Plymouth
    +72
    10% at the very least on B&W
  9. BenW
    BenW
    Jun 3, 2005
    888
    Stansted
    +17
    John, guess you mean most?
    Will have to try for some speaker cable then
  10. windfall
    windfall
    Oct 19, 2003
    2,432
    48
    LFC Kop End
    +68
    There is always plenty of stuff on ebay, but also on the AVFORUMS classified section, also consider putting in a wanted advert, I have seen quite a few 600 Series 3 speakers for sale in both locations. learnt to be a little patient but got what I wanted, and as per usual check em before taking them away.
    Not to scare you but my 602's - when I purchased them (£150) I had no chance to check them,but when I got home I found the tweeter on one of them not working, so called up the seller who came to me the next day and listened for himself. He refunded me £40 which is what it cost me for a replacement tweeter. Sweet. I sold the 601's S2 (in maple) for £140 that the 602's replaced :smashin:
    Tone
  11. windfall
    windfall
    Oct 19, 2003
    2,432
    48
    LFC Kop End
    +68
    Just found this....
    http://www.bw-secondhand.com/index.php
    Could be worth a try, although dealers are moving their speakers around much more then an owner so they may be a bit more damaged!
    Tone
  12. koshatnik
    koshatnik
    Best way of getting money off anything is pay in cash. Prices in shops are guides - no price is fixed, no matter what anyone says. Everyone is flexible. I've got as much as 25% off listed prices for various things, by being persistant and taking cash. Most people don't ask in the UK, we just slavishly pay whatever price the shop displays. All prices are negotiable. I generally find that the more expensive the item, the easier it is to get money off (mark-ups are higher). Have a word with the the shop manager, its always worth a punt. Second hand shops are much easier to sway with cash. Just get it out and fan yourself with it in front of them. :thumbsup:
  13. Kahuna
    Kahuna
    Sep 11, 2005
    630
    London
    +12
    Agreed.
  14. Shin Akuma
    Shin Akuma
    Dec 29, 2004
    2,912
    71
    +95
    I bought brand new B&W ASW675 for £525, which retails for £650 i think.
  15. BenW
    BenW
    Jun 3, 2005
    888
    Stansted
    +17
    Thanks all!
    Will take the advice :)
  16. j0hn
    j0hn
    May 26, 2005
    1,947
    48
    Plymouth
    +72
    Dont settle for speaker cable or anything else if you dont need it.
  17. koshatnik
    koshatnik
    Another tip: If you want to buy several things at once, like an amp and speakers, ask the shop manager what deal he'll give you if you buy both from the shop. Most shop managers will wander off and come back with a deal price.
  18. michael orme
    michael orme
    Nov 18, 2005
    53
    11
    I saw some B&W 602S3 speakers for sale in a hifi shop in Chester, they were always £300, but I thought I would ask anyway, If I wanted the ones from out of the shop window the man wanted £160! He plugged them into a Rotel amp and Rega deck for a listen, and I bought them with a two year guarantee. I have not regretted buying them.
    Michael Orme. Rhyl.UK.
  19. turbo1
    turbo1
    Aug 14, 2005
    39
    yesterday i got 40 of a pair of 602 s3
    today i got 30 of centre
    ordered in for monday
    no probs
    should have offered less :)
  20. nickuk
    nickuk
    Oct 23, 2004
    30
    Stafford / Derby
    I was very lucky to find on ebay two users selling b&w speakers who had treated them better than there kids. So i managed to get 600 s3 for 110 and 125 for lcr60.
    Others though have not been so lucky with there speakers from ebay.
