The A32 cannot be fitted with a DAVE module and there are no plans to upgrade this module, as it would involve a huge amount of work and still fail to solve the connectivity problem (i.e. there is not enough back panel space!). Instead we have put the effort into developing the AV8 - rather more than a million dollars worth in fact.
There is an analogue multi channel module in active development right now for the A32 (and A85) which will accept a 6 channel input from suitable sources like a DVD-A player or SACD player. We will publish the detailed specification when we are ready!
You will need 5 power amps minimum (the 6th channel is usually for a powered subwoofer but in DVD-A can be used as a proper 6th channel with some discs). Of course two of these are already in your A85, so you would need to add 3 more, e.g. using our P85/3 power amp, which has been designed for just this sort of job.
