can anyone tell me what all these temps mean?
Discussion in 'Desktop & Laptop Computers Forum' started by jmack, Aug 6, 2003.
  1. jmack
    jmack
    if you can see them i use speedfan to get them
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,309
    Surrey. UK.
    +2,019
    The 51c temp is probably cpu temp.
    What you can do, is after the pc has been running a while, do a restart, and look in the bios. It will show you the temps of the censors. Write them down, then let the machine start into windows, and look at the temps being displayed as in your pic.
    Hopefully you'll be able to match up the cpu and system temps with those on the display.
    HTH
    Gary.
