Can anyone suggest a Webcam that has a tripod mount?
Discussion in 'Smart Home, Climate Control & Security Forum' started by Cartoonhead, Feb 12, 2016.
Tags:
  1. Cartoonhead
    Cartoonhead
    Feb 5, 2011
    4
    Hi Folks
    Can anyone suggest a cheapish HD webcam that can be mounted on a tripod or gorilla mount.
    I'm looking for something that can sit inside my house window and keep watch of my car.
    PS : I'm in a rented property so can't mount anything on the outside of the wall
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Most "cheapish" webcams have the standard tripod mount. We have used TrendNet range but plenty of others
  3. Sun
    Sun
    Oct 8, 2003
    804
    28
    Stowmarket, Suffolk
    +39
    Not sure what level of cheap you're looking for but I have a Logitech C920 HD webcam which I have used with a tripod. Pictures are excellent, it's highly rated if you do a quick search. Has movement detection and tracking as well which might be helpful if you're concerned about a vehicle.
