Can anyone recommend me some floorstanding speakers
hkrdan
Hi folks. I’ve got an old Teac Reference 500 Ah500i amp and matching CD player. Can anyone recommend some floorstanding speakers that’d be a good match.
As usual I’d like to spend as little as possible, but max budget is about 400 unless it’s worth spending a bit more for a lot better.
Any advice appreciated :)
Orobas
ex demo pair of monitor audio radius 270 works really well with the teac, we have this combo at work and that is in a 5x4m room...
Paul7777x
If you’re anywhere near these they are a very good, quite easy to drive speaker.
password1
The Teac system may not be good enough for these speakers.
I would consider adding to the shortlist a pair of fyne audio f302
BlueWizard
The Monitor Audio Bronze 5 (2x5.5", £550/pr Suggested, Currently £350/pr) are pretty well regarded in reasonably compact Floorstanding Speakers -
That is a very decent price in a NEW speaker. I believe Monitor Audio has released a New Bronze Series, so this is remaining stock in the previous series. But the Bronze 5 have been very well regarded.
Steve/bluewizard
hkrdan
Thanks guys, lots of food for thought there. I’d heard good things about the Fyne’s, but the bronze 5’s look excellent for the money.
password1
I think you'll need to upgrade the teac amp to get near the best out of any of the speakers mentioned above.
I had an expensive all in one teac system and it was crap. mid range was thin, lacking detail and bass muffled.
i took it back and exchanged it for an amp for the same price.
hkrdan
It’s not an all in one system. I’ve demoed many a more modern amp over the years and not heard much better that won’t set me back a small fortune. I’m not saying it’s top-end, far from it, but the reference 500 series are good solid hifi separates.
password1
the teac system i bought was an alternative to the denon dm30. it was about £300 almost 20 years ago. no speakers included.
its expensive for the sound quality. a £59 cambridge audio a1 mark 1 sounded much better with my £39 jpw ml310i speakers and sony walkman portable cd player
BlueWizard
Any time you buy a Micro/Mini-Amp you are buying a compromise, but that is Audio Life, we are all trading something for something else.
One of the best sounding amps I ever owned, and one I had for decades was a 45w/ch Pioneer (full sized). And I consistently drove large 12" speaker with that amp.
So, unless the rated Sensitivity of a give speaker is low, I don't see much problem using floorstanding with a 45w/ch amp.
But as I said when you buy a Compact Amp, you are buying compromises.
My impression is that the Thread Starter has had the TEAC for quite a while and seems very satisfied with it. So, not sure we need to go there.
Now certainly a full-sized higher-powered amp would be better. But that is kind of a rabbit hole that a person can get lost in. There are always bigger more expensive higher powered amp to be considered.
The Monitor Audio Bronze are rated at 90db Sensitivity, and that should be high enough to be driven by just about any Amp. Just a guess, but I would say any speaker 87db and above are going to be fine.
Now you are all free to have any opinion you want about the TEAC, that's fine. But for a vast majority of us, we play with the amp we have, not with the amp we want.
I think most of us are engaged in Stepped Upgrades. That is, we upgrade one item at a time, step by step, rather than entire systems. Right now Floorstanding is the step that the OP wants to upgrade. Later when the urge strikes he will probably upgrade the amp. But for now ... one Step at a time.
Steve/bluewizard
Hixs
£350 is an absolute steal for a new pair of those.
Paul7777x
The op’s amp will not have problems driving any of the speakers mentioned here.
It was a serious attempt by Teac to make a real amp in a small case.
Hence the 350W potential power draw.
Plenty of current to drive anything in this kind of league to rather impressive levels.
Paul7777x
Steve/bluewizard
Good call sir.
Other than used, like the Regas, or refurbed, like the CAs mentioned earlier, it’s hard to see past these at this price.
password1
im not saying it will have problems driving the speakers above. there are better amps that will get more out of the speakers.
boristhespider
I cannot recommend the MA Bronze 5s enough, and at that price they are a steal. I purchased the MA Bronze floorstanders from RS about 3 years ago (£650 !!) when I got back into HiFi. I ran them off an old 80s Yamaha A300 amp (brill in its day) and an Onkyo CD player and an old 80s Akai AP90C turntable. I gradually upgraded everything over the years via Marantz stuf... to now, where I have Naim XS3 amp, Naim CD5si CD player and a Rega P8 deck.......but the MAs have remained. They have, time and time again, passed muster with ease, keeping up with the upgrades. They are probably maxed out now, but I do not intend to go any higher in cost. The MAs just disappear. they will be more than adequate for your current stuff and see you through many upgrades. At that price, you will not do better. Best of luck with whatever you go for.
Jester1066
Hi @hkrdan
Jus wondered what speakers you ended up getting?
LG CX 4K OLED TV Review: The best TV of 2020?
Trending threads
