Can anyone recommend a good car tyre pump?
Discussion in 'Motoring' started by shahedz, Jul 3, 2015.
  1. shahedz
    shahedz
    Apr 26, 2005
    11,105
    +2,038
    Ideally Electric and one with an electric gauge.
  2. un1eash
    un1eash
    Nov 14, 2007
    5,031
    2
    +1,451
    Don't waste your time or money with an Electric one, I've had at least 3 now and they all broke after a couple uses.
    I now use this Michelin one from Halfords as I wanted a digital gauge...
    Halfords | Michelin Digital Single Barrel Footpump
    Couple negatives are the screw on valve lets a bit of air out when releasing and it doesn't have a release button on the hose to purge air when you've over filled.
  3. FZR400RRSP
    FZR400RRSP
    Mar 5, 2007
    32,038
    Aberdeen
    +10,374
    I also prefer a manual one.
    I have a Michelin double barrel foot pump.
    The gauge on it seems pretty accurate, but I use it in conjunction with a separate digital gauge (which I get calibrated on the sly with work tools) :)
  4. AMc
    AMc
    Nov 20, 2000
    7,618
    Near Norwich
    +4,363
    I have one of those jumpstarters which has a 12V compressor attached £30.
    I bought it because it was cheaper than getting the car towed to have the battery replaced.
    The compressor has inflated countless tyres, paddling pools etc. I've had it 10 years and a month according to my email.
    The jumpstarter battery is no longer up to starting a car but the compressor keeps going.
    Sorry I can't give a recommendation as the stickers fell off after a couple of years and CPC no longer recognise the product code.
    Maplin have a number of similar things.
    Jump Starters | Maplin
  5. p3x289
    p3x289
    Dec 3, 2005
    828
    +69
  6. un1eash
    un1eash
    Nov 14, 2007
    5,031
    2
    +1,451
    I've had the Ring RAC600 and the Ring RAC635, both broke after a couple uses. Dad also had a RAC600 which broke. I cant rely on them to work when needed so use a manual one now.
  7. MarkyPancake
    MarkyPancake
    Jan 30, 2006
    17,709
    UK
    +3,835
    I got one a few years ago that looks exactly like that Ring Automotive one, but without any branding on it, and found it a faff to use, the gauge wasn't accurate and it would overfill when using the auto shut-off feature, making that useless, so I went back to a footpump and separate digital gauge and have never used an electrical pump since.
  8. gibbsy
    gibbsy
    May 17, 2007
    14,558
    3
    Cwm Cynon, De Cymru
    +8,396
    I cannot use a foot pump so it has to be an electric. Couple of years ago I bought a Halford's 239066 model. Works very well and the guage is pretty accurate. Still got the old fashioned pressure tester I bought when Adam was a boy.
  9. IronGiant
    IronGiant
    Jun 7, 2003
    67,585
    +48,375
    Just checking, you don't have a son called Adam, do you? :)
  10. shahedz
    shahedz
    Apr 26, 2005
    11,105
    +2,038
    Thanks for all your replies. I'm surprised the electric ones are so poor. Have bought a manual foot pump michelin double barrelled with the digital gauge. Thanks again all.
  11. FZR400RRSP
    FZR400RRSP
    Mar 5, 2007
    32,038
    Aberdeen
    +10,374
    Ooh, they do one with a digital gauge now?
    Nice, time for me to upgrade.
  12. shahedz
    shahedz
    Apr 26, 2005
    11,105
    +2,038
    They sure do. Ordered one from Amazon. Hopefully here in a few days.
  13. wack
    wack
    Jul 21, 2005
    4,300
    Warrington
    +834
    I bought one with a 2l coke bottle shaped tank, it's surprising how handy a little compressor is, I bought a nail gun from Aldi and used it to build a fence, cleaning stuff with compressed air is useful , it was about £100 in Costco but I know in 5 years it'll still be working and it pumps tyres up in seconds not hours
    I've seen something similar in lidl for less money
  14. shahedz
    shahedz
    Apr 26, 2005
    11,105
    +2,038
    Used the Michelin this weekend, very pleased. Gauge is nice and easy to read, much better than the analogue one for me.
