Can anyone recommend a DVD lens cleaner
Discussion in 'Blu-ray & DVD Players & Recorders' started by Tracey, Oct 20, 2003.
  1. Tracey
    Tracey
    I need a lens cleaner for my DV27, can anyone recommend one and where I can get it from online.
    Thanks,
    Tracey
  2. Garrett
    Garrett
    Apr 21, 2001
    40,249
    2
    167
    The best thief you’ll never see.
    +6,672
    My father picked a CD cleaner up in one of those pound shops, when I looked all it was, was a little bit of brush about 7-8mm long and very thin at 90degrees to the axis I thought it was a bit naff.
    I wondered how the dearer ones worked. I was at the show at weekend and opened one for a DVD from a well known make I was taken aback it was the exact same design only a lot more pound.:eek:
  3. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    Allsop do a good DVD Optimiser/lens cleaner.
  4. Tracey
    Tracey
    Yes I must admit they do look pretty cheap but I don't think I can get my fingers in there to clean it :D
  5. Tracey
    Tracey
    thanks I'll have a look for that.
