Can anyone recommend a decent interconnect
Discussion in 'Cables & Switches' started by mandril, May 1, 2004.
  1. mandril
    mandril
    Jan 12, 2003
    174
    19
    I've just started looking at buying some interconnects to go between a Tag AV32R DP (hopefully) and rotel 1075+1070.
    Can anyone recommend any decent cables. Are there any major differences between manufacturers?
    Or is a entry level chord better than an equivalently priced QED for example.
    I was looking to spend around £40 a pair
    Cheers Ricky
  2. bobbypunk
    bobbypunk
    i'm sure that doesn't come close to what you should use with your equipment but I reckon VanDenHul are probably the safest bet at any price.
  3. Hawklord
    Hawklord
    Feb 15, 2003
    3,601
    4
    Aldershot, Hampshire
    +326
    I've tried a few cables but nothing has beaten my Van Den Hul D-102 III Hybrid cable as yet. It won a What HiFi award but iirc it's slightly over your budget (but worth every £ imo). I also use their Teatrack speaker cable to bi-amp my speakers which I'm very happy with too:)
  4. mandril
    mandril
    Jan 12, 2003
    174
    19
    three pairs of van den hul 102's markIII went for around £40 a pair on ebay the other day, although they wern't listed as hybrids. (does that make a difference)? I have already sorted speaker cable Im using QED silver anniversary (I needed over 50m and its the best I could afford).
    So I could get the 102's second hand or QED Qunex 4S new, or chord cobra's new. (for example)
    Opinions??
    Thanks Ricky
  5. bobbypunk
    bobbypunk
    Qunex4s are good interconnects.
  6. mandril
    mandril
    Jan 12, 2003
    174
    19
    just got 3 pairs of VDH 102's £35 a pair off ebay
  7. BazH
    BazH
    DNM Reson/Eichman Bullet - spacious/clarity/stunning
  8. pringtef
    pringtef
    Sep 30, 2003
    1,072
    Amsterdam
    +70
    Agree with BazH, DNM Bullet stuff is shecht hot. Not particularly cheap circa £80 for a 0.5 metre pair, but the performance from them is stunning. Every interconnect on my hi fi is now this stuff
    Their speaker cable is pretty hot as well!
  9. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,328
    2
    +3,924
    The Precious Metals Coppertech Alpha is only £25 but it is a very good cable indeed- used to be used at a suprising number of our shows until the Marantz/ Audioquest tie in. Mark Grant's analogue interconnects won't be too shabby either.
  10. Filbert
    Filbert
    Apr 6, 2004
    962
    46
    Pinner
    +195
    FYI, we sell the DNM Reson Bullet interconnect for £74.99 for a 1m length.
