Can anyone recommend a decent budget Sub?
Discussion in 'Subwoofers' started by Neurotic, Apr 30, 2001.
  1. Neurotic
    Neurotic
    I'm looking to buy a budget (cheap!) sub for round £150 to £300 if poss - anyone recommend anything?
    Cheers,
    Rob
  2. stefinch
    stefinch
    I have a kef coda S it's 100w active and for the cash it's great about £200 but I know HYPER-FI did have them at a special price, dont know if they have any left but it's worth a call. Also i've heard that the IPL sub kit that you build yourself is leathal it's less than £300. Find it in the back of HCC mag. Check the photo of the Kef sub on my site
    MY HOME CINEMA
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Try the Paradigm PDR-10 from Richer Sounds.
    great sub, popular and very good value.
    Rick
  4. mark.king
    mark.king
    Buy the kit from iplacoustics this will cost
    less than £300 and is excelent and simple to make. It must be because I made it. IPL claim it is as good as subs above £700.
  5. Neurotic
    Neurotic
    Cheers Guys!
    is this the IPL you're on about?
    IPL SW2 ACTIVE SUBWOOFER
    Rob
  6. philmate
    philmate
    Nov 6, 2000
    217
    Southend-on-sea
    +4
    That's the one and is easy to put together cause I built one too.For £285 all in it's more than a bargain and you can finish it any way YOU like. I'm seriously thinking about getting 4 avr2's and the avc 2 from Ivan, he's upgrading the tweeters begining of June,prob £250ish a pair, speakers that is, but I'm not 100% sure whether to go for these as rears or buy some bi-pole/di-pole instead as these will be just behind me 5ft either side.. any takers anyone.
    Philmate. :rolleyes:
  7. mark.king
    mark.king
    Yup thats the one. The best suprise for me was how good a finish you can get with the iron on veneer. The real wood finish is better than most commercial plasticy finishes
  8. Frustin
    Frustin
    where do you get these DIY woofers? can you show a few urls please?
    apart from www.iplacoustics.co.uk
    Is that woofer shielded? if not how far away does it have to be from the tv?
    EDIT: No they are shielded (i phoned the guy).
    [ 02-05-2001: Message edited by: Frustin ]
