Can anyone recommend a 4 input (separate tracks same time) Audio Interface?
Discussion in 'Pro Audio and Musicians Forum' started by Maniac618, Mar 4, 2013.
  1. Maniac618
    Maniac618
    Jan 7, 2004
    837
    28
    +26
    Ideally 1/4 inch jacks for guitar and also sockets for mics.
    I want to be able to record 3 guitars at the same time and maybe a mic as well all on separate tracks in software (not doubled up or mixed together as one track).
    I have an Alesis io4, but I believe it to be faulty and will be returning it unless anyone can help here:
    http://www.avforums.com/forums/musi...-audio-interface-noise-problem-any-ideas.html
    Thanks for any tips / ideas.
  2. suniil
    suniil
    Jan 24, 2005
    4,948
    London SE5 / W1
    +402
    I'm not knowledgeable as other members, but I use Tascam DR-680 to record audio. Have a research and see if that suits you.
  3. Maniac618
    Maniac618
    Jan 7, 2004
    837
    28
    +26
    Looks very nice but far too overkill for me and the price, golly!
  4. duncfunk
    duncfunk
    May 8, 2009
    2,331
    +462
    What's your budget and do you have any existing recording software?
  5. Maniac618
    Maniac618
    Jan 7, 2004
    837
    28
    +26
    Under £200, but nearer £100 if possible. I have an iMac 2009 model (8gb of RAM, core duo intel processor, firewire & usb) and I have Logic Pro 9.
  6. duncfunk
    duncfunk
    May 8, 2009
    2,331
    +462
    Ok for that budget you're looking at an interface with 2 mic pre-amps and 2 or more line inputs. I'd always recommend Focusrite gear as their pre-amps are right up there with the best. My money would be on this one:
    Focusrite Saffire PRO 14 Firewire Audio Interface | DV247
    The price is showing in Euros for me but it should be around £150-160. Firewire is also a bonus as most units in this price range are usb :smashin:
  7. Maniac618
    Maniac618
    Jan 7, 2004
    837
    28
    +26
    Looks good, just not quite enough guitar inputs though. I need 3, but that one has 2 unless I buy a DI box for one of the rear inputs, is that correct?
  8. duncfunk
    duncfunk
    May 8, 2009
    2,331
    +462
    That's correct but you'll only find interfaces with 2 or 4 pre amp inputs. If you go up to the 4 category you can probably add another £100 on to the price. Budget wise it makes sense to just use a DI box on the line input channels :smashin:
