Can anyone reccomend a 60mm Silent case fan
Discussion in 'Desktop & Laptop Computers Forum' started by cowtipper, Sep 22, 2004.
  1. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,192
    +1,236
    Does it have to be 60mm , how about an 80mm?
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I've read PAPST are very good but don't know a source. I use Vantecs which are reasonably quiet but can have a tendency to buzz from time to time .. a Zalman Fan Mate usually solves that problem.
    60mms are hard to make effective and quiet at the same time sadly. I have an Accent HTPC case which only takes 2 x 60mms at the rear. :(
  4. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    Silenx fans are great, got one on my silverstone case and it beats teh pants off the papst I had.
    Chris
  5. jimbob19
    jimbob19
    Sep 5, 2002
    1,543
    Dunstable
    +50
    Another vote for silenx here :smashin:
  6. kevinwilson
    kevinwilson
    Sep 2, 2003
    28
    Bedfordshire
    After a lot of research, I've recently gone for an 80mm SilenX fan for my Xbox, and I agree completely with Jimbob and Chris - I'm amazed at how quiet it is :)
  7. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Can one of you Silenx users please tell me where I may find these? I've heard of them but haven't found a supplier so far .. and like cowtipper I must have 60mms.
  8. kevinwilson
    kevinwilson
    Sep 2, 2003
    28
    Bedfordshire
    I got mine from http://www.kustompcs.co.uk/, who I can highly recommend for speed of delivery.
  9. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Thanks Kevin .. a new supplier to me .. 12Dba, that's QUIET! :)
    And out of stock. :suicide:
  10. Yandros
    Yandros
    Oct 13, 2003
    2,714
    +528
    I use Papst, both regular and temperature controlled.
    http://www.chillblast.com/customer/product.php?productid=16458
    The temperature controlled 80mm Papst exhaust fans I've fitted in a P4 3.2 only run at about 500-1000 rpm most of the time, 1400 at most, and are practically inaudible from more than about 6" away
  11. jimbob19
    jimbob19
    Sep 5, 2002
    1,543
    Dunstable
    +50
  12. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    I used sosilent too, cheaper than kustompcs I think. Be aware that the 8dba fan doesn`t really push a lot of air.
