Can anyone here mod xboxes
Discussion in 'Xbox Forums' started by Dextur, Sep 13, 2004.
  1. Dextur
    Dextur
    Aug 30, 2004
    10,331
    +1,754
    Is there any one here who can
    a) Mod an xbox with a decent chip, Executor 2.6 with the on/off switch , led indicator etc.
    b) Covert it to NTSC using enimga etc
    c) This one not that important but do the custom job, silver skin/transparent jewel, blue lighting undercarriage, port controllers, top and on/off button in blue.
    Dammed if I can find somebody who can do all three properly
    Just PM me
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  3. Dextur
    Dextur
    Aug 30, 2004
    10,331
    +1,754
    Thanks PJ will check it out.
  4. Dextur
    Dextur
    Aug 30, 2004
    10,331
    +1,754
    They don't do executor chips or customisation internal lighting etc or the enigma flash LOL. But good site will be useful for some people.
  5. jamesvtidohc
    jamesvtidohc
    Sep 8, 2004
    890
    London mate
    +26
    why not, check out www.xbox-scene.com and click on the 'forums' tab, youll find lots of **** on xbox's there. the enigma isnt a flash bios, its just a disc converter, ive got one myself
  6. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    1) you don't need executer chip, any will do, alladin has on/off and IMHO far better than executer
    2) they load enigmah video switcher on your Hard Disk, as a util
    3) they do sell skins, but you have to fit em
  7. Dextur
    Dextur
    Aug 30, 2004
    10,331
    +1,754
    PJ, thing is I want the whole thing done in one place, the skin is not so hard but the transparent jewel, blue backlighting on controller ports, jewell and power switch is not something I want to touch. Re alladin, good point the problem is i really don't know which chip is the best, I'm just after something that will allow me to get to NTSC output, not overly fussed about all the other stuff. Re the eimga somehwere on their site it says the customer needs to do that bit.
  8. Dextur
    Dextur
    Aug 30, 2004
    10,331
    +1,754
    PJ which Alladin do you have, and also does it have an actuall physical on/off switch on it like the Executer does and lastly does the Enigma NTSC switching s/w work with the Alladin?
  9. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    I have an ancient Executer 2, I didn't bother to solder an on/off switch in.
    Enigmah works with any chip, or no chip if you use a soft mod. It's a homebrew
    app. works with any bios that allows homebrew to work (IE any 3rd party bios)
    ALX2 works by pressing combinations of existing buttons (on front of xbox)
    very easy and almost idiot proof.
  10. Dextur
    Dextur
    Aug 30, 2004
    10,331
    +1,754
    ah ok, sounds good thanks PJ
