can anyone help ????
Discussion in 'Plasma TVs Forum' started by markevo, Aug 26, 2004.
  1. markevo
    markevo
    Aug 19, 2004
    32
    liverpool
    Hi all
    I am buying a plasma screen and need help deciding which one to get.
    could anyone with a bit of experience point me in the right direction as to which model ?.
    have heard everyone talking about the panasonics but when i enquired about it shop staff were a bit unhelpfull saying about it being vga only ?
    i just need to know what sort of spec i will need for home viewing of tv and dvds.
    also i hear something about it needing to be hdtv compatable ?
    im looking at spending about £2000. for screen and stand/wall mount.
    any info would be a great help
    Markevo
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Which shop, utter stupidity on there part....
    Fujitsu VCA, Panny PW6 and NEC (whatever themodel number, have a search) should be on top of your list.
    £2k doesnt buy a lot of plasma, but gets you well on the way......
  3. markevo
    markevo
    Aug 19, 2004
    32
    liverpool
    believe it or not it was richersounds, i went in and asked about the panny th42pwd6bx
    @£1899. and was told this was a vga only plasma that they have hanging in airports and i would be better off getting the toshiba 42pw37 @£1799.
    Totally confused me so i left to do more research.
    still finding it hard to pin down a model though. ?
    Markevo
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Well that explains a lot! Panny must be getting desparate to shift PW6 volumes before PW7 hits ........... Also bypass RS go to avsales (see powerbuy forum) and get a properly specced plasma with everything you need!
