Can anyone help me i promise this will help you back
Discussion in 'PC Gaming & Rigs' started by tony kop77, Mar 20, 2003.
  1. tony kop77
    tony kop77
    Sep 27, 2002
    5,825
    83
    Northamptonshire
    +170
    To uninstall programs is it best to go to control panel and remove programs. I want to delete the cm4 beta demo. I want to delete some other programs do i do it this way or go to the start menu and click uninstall on that.
    PS the cm4 gold demo is now available to download at the home page told you i could help you back
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Use the uninstall program that came with the program. This should match up with the add/remove programs list.
  3. tony kop77
    tony kop77
    Sep 27, 2002
    5,825
    83
    Northamptonshire
    +170
    Thank you. I did have winrar to unzip files but i am not familar with that so i have decided to install winzip because i have used this in the past. Is winzip regarded as a good program or do you recomend any others.
    PS is anyone trying to download the gold demo. This demo has fixed all the known bugs the demo out before was a beta.
    www.sigames.com
