Can anyone help me find speakers for my vintage radio?
Discussion in 'Music Streamers' started by John Watts, Feb 11, 2009.
  1. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    Hi all please can you help point me in the right direction. They seem to need spade like connectors like in the pics.
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    You need 2 pin DIN male plugs. Maplin part number L64BA will get the job done.
  3. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    Could bare speaker wire be inserted?
  4. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,184
    +7,321
    I guess you could but you'd need a pretty thin wire. It would probably also need to be "tinned" with solder to give it rigidity & reduce the risk of a whisker short.
    By the time you've done that you may as well fit the proper plugs. You can get screw fitting versions so no soldering required if that's your concern. Also available in right-angle.
