Can anyone help locate this bloody connector?
Discussion in 'Desktop & Laptop Computers Forum' started by pcavelle, Aug 13, 2004.
  1. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    Hi - I have a Radeon 9500 Pro in the back of my PC. On of the outputs is described as S Video, but it is not. It has 6 or 7 pins instead of the usual 4 and is some kind of proprietary connector.
    Can anyone advise where I can get a suitable connector/cable/adaptor so I can get a pukka s video cable connected to the damn thing?
    Paul
  2. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
    You don’t need an adapter - the standard 4 pin s-video cable actually fits that socket. ;) and only uses 4 of the 7.
    I think the socket is a multi use, composite, s-video and component.
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,489
    South Derbyshire
    +198
    True - 4 pins svideo fits in the 7 pin socket.
  4. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    Thanks Chaps but it doesn't. There is a bend or curve in the perimeter of the proprietary socket that prevents an s video from being pushed in, unless I'm being thick about this, and trying it upside down or something like that.
    Have you actually got Radeons yourself & tried this, may I ask?
    Paul
  5. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,489
    South Derbyshire
    +198
    Yes - I have a Radeon 9000, 9100, 9600XT, 9600pro, 9700 and the Svideo just fits in no probs.
  6. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    Sounds like your connector or lead have got bent somehow. Radeons don`t come with proprietary connectors.
  7. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    try a different S-video cable the socket is actually a mini Din, S-video normally uses 4 pin mini DIN but there are loads of types of DIN connection (DIN is a german standard for connections), including those used on Scuba gear.
  9. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
    A standard s-video 4 pin connector definitely fits, the 7 pin socket on my 9500pro 9600pro and 9000, just to make sure a tested this again before my post this morning.
    I have had a couple of ATI video cards (retail boxed) and all had a 2mtr s-video cable included, did you not get any cables with your card?
    My 5 mtr IXOS S-Video cable also fits
    Looks like its your cable ;)
  10. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    Thanks chaps - it must just be me being a pratt. I'll give it another try later using a different cable.
    I did get something or other when I bought it but have lost the box. Regards
    Paul
  11. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    It was the cable, just too thick to fit in and another one worked ok.
    A question - using the s video output from the Radeon should I be able to get a clear picture into my LCD TV/monitor? It's really blurred compared to the normal VGA cable.
    Is s video capable of outputting a normal computer video signal?
    Thanks for your help,
    Paul
  12. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,489
    South Derbyshire
    +198
    Svideo from gfx cards sucks to be honest - VGA should be used where possible.
    The only respectable Svideo out I have seen from a PC is from a Sigma Holloywood+ card or a Sigma Xcard.
