can anyone explain resolutions please
Discussion in 'Desktop & Laptop Computers Forum' started by Threadkiller, Feb 19, 2003.
  1. Threadkiller
    Threadkiller
    Aug 23, 2002
    63
    Ok I have a Panasonic LC75E. running on a HCPC with a Radeon 9000 but I'm confused as to the resolutions
    the default is given as XGA (1024*768)
    But it will also work at 480i; 625i; 480p; 720p; 1080i
    and its these I have a problem with, what do I set my PC resolutions to?
    I've looked at powerstrip settings, but am unsure as to which of the multiple options to match these settings to use.
    any help gratefully recieved
  2. Threadkiller
    Threadkiller
    Aug 23, 2002
    63
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,061
    +1,149
    Ideally you want to match the native panel display resolution and refresh rate ( normally 60Hz with LCD but not always). If you don't match the panel res then scaling will be taking place which in most cases is less than optimum on the display.
  4. Threadkiller
    Threadkiller
    Aug 23, 2002
    63
    Thanks for the Reply Mr.D. I understand the scaling bit, which would be the XGA (1024*768), but if the projector will run at the given HDTV definitions, and that better suits my screen etc, I can't seem to grasp which I should use? or would these HDTV settings apply to an s-video I/p rather than the 15way dsub?
  5. olaiho
    olaiho
    Threadkiller,
    read these threads:
    Link
    Link two
    Those threads contain some explanations, and also instructions on how to get optimum picture settings with a HTPC+projector combination.
    BR,
    Olaiho
  6. Threadkiller
    Threadkiller
    Aug 23, 2002
    63
