Can anyone confirm if this wireless router package is all I need?
Discussion in 'General Video Gaming Chat' started by Tetlee, Aug 7, 2004.
  1. Tetlee
    Tetlee
    Jan 21, 2004
    20,266
    Taunton
    +4,765
    Hi all,
    Been trying to decide just what router package to buy for my consoles for ages. I like the idea of going wireless and I think this seems a good all in package http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X3Jldmlld3M=&product_uid=63549 The problem is I really don't understand exactly what I need so I would like confirmation from someone that this SHOULD work before I buy.
    OK, here's how I plan to set it up if it's possible? I guess I will first need to configure the router via my pc. Then I hope to plug the router into my phone filter in the lounge so I can directly connect my xbox/PS2, then use the wireless pc card to allow connection to the pc (which is a seperate room). Is it possible to do it this way or do I really need to have the router plugged into my pc and buy a gaming adaptor (which will be alot more expense)?
    Also, I noticed this one looked like another good option and I guess the same question would apply http://www.ebuyer.com/customer/prod...kdWN0X3Jldmlld3M=&product_uid=56082&offset=30 This one is cheaper but I notice that alot of you guys seem to like the Linksys gear so I will probably pay the extra.
    Any advise or opinions would be welcome and appreciated, maybe I can finally get this sorted before Doom3 is released :thumbsup:
  2. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    This should do exactly what you want.
    You'll be able to connect your consoles with a cable apiece to the main box and your laptop will connect wirelessly using the PCMCIA card.
    You will have to configure the box using your PC, but this is a one off.
    This is a very similar setup to what I run, except I have a standalone ADSL modem (connects via Ethernet rather than USB) connecting to my wireless router. Lucky I did as the wireless router went bang last week and I had to get it replaced under warranty. As the modem was fine, at least I could still get online, albeit whilst "tethered" ;) by a bright blue Ethernet cable.
  3. Tetlee
    Tetlee
    Jan 21, 2004
    20,266
    Taunton
    +4,765
    Thanks AOD, now I can go ahead and order, I hope all goes ok with setting the thing up, more than likely I'll be back here for advise on that too :blush: .
    I will order tonight, does anyone have any opinions on either router I listed above?
    I think I'll opt for the Linksys unless someone advises otherwise.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    my hate has the linksys and was fine, just make sure ADSL is all set-up first as he had an issue with AOL Broadband. should be easy enough to set-up just follow manual, but set-up the modem using a cable first before going wireless.
  5. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    You're welcome, if you do have any serious issues and we can't resolve them, take a look at AdslGuide.
    Personally I would go for the Linksys in preference to the other one mentioned, also as hornydragon says, set it up first with a cable and get online before switching to the wireless card (assuming your laptop has an inbuilt Ethernet socket of course ;) ).
  6. Tetlee
    Tetlee
    Jan 21, 2004
    20,266
    Taunton
    +4,765
    Actually I don't have a laptop. I will be connecting the Xbox and PS2 directly to the modem/router, and then using the wireless pc card in my desktop pc. I hope this doesn't make a diferance, I just ordered the Linksys so if you think there might be a problem with that set-up please let me know ASAP incase I need to cancel the order. I's so difficult to know what I need, everyone seems to have a different type of setup and in throughout the reviews in ebuyer none I could find had a setup similar to what I am planning, hence the caution.
    Anyway, thanks again!
