can anyone answer this for me ????
Discussion in 'Plasma TVs' started by MULLY@110, Sep 1, 2005.
  1. MULLY@110
    MULLY@110
    May 19, 2005
    151
    +6
    is it true you should never site your plasma above a fire as looked at some of the pics of peeps setups on here and a few have done just that can anyone help b4 l make this mistake ? :confused:
  2. Korum
    Korum
    Feb 19, 2005
    4,260
    Stockton-on-Tees
    +691
    Yes you're right it shouldn't be done especially on November 5th.
  3. MULLY@110
    MULLY@110
    May 19, 2005
    151
    +6
    lol korum thats where mine will probably end up
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Tho this is a fine location if Prescott is on news24 at the time....
    Seriously, as you see, many people do this, and it's fine as long as you are not smelting iron in the fireplace. If it's a real fire, I'd be cautious, not very controllable heat wise. If it feels a bit hot, you can't just turn it down. Most gas and electric fires are fine, a good solid mantelpiece helps. The cables can be problematic, you must not crack the flue, or let the cables melt.
  5. MULLY@110
    MULLY@110
    May 19, 2005
    151
    +6
    cheers maw,
    lt will be a flueless fire that l will be using think these circulate the heat inside the actual fire :rolleyes: :rolleyes:
