Can anybody see anything i have forgotten for my HCPC?
Discussion in 'Desktop & Laptop Computers Forum' started by oreoboy13, May 18, 2004.
  1. oreoboy13
    oreoboy13
    Can anybody see if i have forgotten anything obvious?
    Samsung SpinPoint P80 160gb SATA £83.00
    SilenX 300w iXtrema Pro PSU £59.95
    A7N8X-E Deluxe SKTA NVNorce2ST £57.99
    2 x Crucial 512 DDR400 PC3200 £124.04
    Ebuyer Internal 7 In 1 USB 2.0 Card Reader Black £7.76
    Nec 8x DVD Dual R/RW IDE BLACK Burner - OEM £49.93
    Super Flower SF-464T2-BK Rhythmic Black Atx Case With Side & Top Windows and Front Cathodes £21.99
    Used Ag Neovo F-419 Black 19ins Tft Analog And Dvi £279.74
    Sapphire Atlantis Radeon 9800 PRO 128 MB DDR 8x AGP DVi & TV-Out £131.98
    AMD Athlon XP3200 400FSB Retail Boxed Inc Heatsink & Fan with 3year Warranty £114.65
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    I budget for a sound card and other heatsink and fan, the onboard sound may fall short or the retail HSF be to noisy.
  3. Cameron
    Cameron
    what about getting a RME 9632 sound card?
    CaM
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,135
    +1,179
    Good analogue capture card?
  5. oreoboy13
    oreoboy13
    i'll grab a capture card from my local store once the rest is up and running, i think i'll go for the RME once everything else is ironed out.
  6. Cameron
    Cameron
    yep, good idea. Once you get a RME9632 you'll be needed CAT5 cable and madnat adapters as well.
    CaM
  7. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,276
    Berks, England
    +131
    I just read that "the SilenX 400W is based on a Fortron-Source. On the outside, except for the big ExoticPC SilenX label, this PSU looks identical to a Fortron-Source FSP400-60PFN"
    Ref: http://www.silentpcreview.com/article81-page1.html
    It may open up your price options a bit for such a psu.
    regards,
    Rob.
  8. oreoboy13
    oreoboy13
    Rob,
    Thanks for the help but too late now, ordered about 10 minutes ago.
  9. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,276
    Berks, England
    +131
    Nevermind.
    There looks to only be a £20 difference and the slienX ones may have improved fan internals, or not! http://www.microdirect.co.uk/productlister.aspx?GroupID=505
    The silenX ones are definitely well reviewed and look a great choice for a HTPC. It's annoying that the majority available to the UK are the less efficient passive PFC types though, or I'd have one to try against the Zalman I'm using.
    regards,
    Rob.
