Can anybody answer this??
Discussion in 'Plasma TVs Forum' started by AndrewTheMuppet, Dec 15, 2004.
  1. AndrewTheMuppet
    AndrewTheMuppet
    Dec 3, 2004
    195
    +3
    Does anybody know if the component board for a PW7 will auto switch between progressive and interlaced.
    The reason I ask this is coz my Brother has a sony projector that won't.
    He uses a Denon AVR 3803 to switch all his video sources which then upconverts everthing to component and sends it to the projector.
    Problem is if he's watching SKY (interlaced) and then decides to watch a DVD (progressive) he has to switch the projector over to progressive which is a pain in the arse!!
    So if I get a Progressive DVD player will I have to do the same with the PW7 or does it autosense the signal type and switch over??
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Yes it will
  3. AndrewTheMuppet
    AndrewTheMuppet
    Dec 3, 2004
    195
    +3
    Well, that was a straight forward answer !!!
    Cheers Maw. :smashin:
