Can anybody advise me of a great player with these specs?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Argento, Jan 20, 2003.
  1. Argento
    Argento
    Ntsc progressive, dts es & dd ex, DVD-A, SACD, multi-region, component output, 5.1 audio out....
    (Ideally from Richer!)
    Thanks folks!
    Rich
  2. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    No ... 2 come close (from memory)
    Pio 656 ... no NTSC prog scan
    Philips 763 ... no DVD-A
    Actually now I think more the Marantz 8300 might do everything you want.
    I don't think any but the Pio is avaliable from Richer Sounds though.
    Victoria
  3. Costas
    Costas
    Jan 14, 2003
    1,662
    63
    Swindon, UK
    +121
    Argento,
    If your A/V receiver/amp supports DTS-ES and DD-EX and connect through optical or coaxial from the DVD player why do you need the decoder on the DVD machine.
    Anyway I recommend Pioneer DV-757ai new flagship model. It has pactically everything on it and its performance is outstanding. A lot of its features are good for whatever is going to come into the future.
    Check it out!
    All the best
