Can any VCRs record PAL60
Discussion in 'Digital TV & Video Players & Recorders' started by Jon Weaver, Oct 11, 2001.
Tags:
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    Born in Bristol but now in Newport, (for my sins)
    +739
    I am currently lucky in that I have a Samsung 709 which outputs in PAL50.
    But my new player only does PAL60.
    Are there any VCRs on the market which can record a PAL60 source?
  2. Cliff
    Cliff
    Mar 17, 2001
    6,333
    167
    Kent Accra Rub Al Khali
    +3,761
    Yes there are, but the problem is they don't say they do. I have a Sony which plays back NTSC. Just as an experiment I tried recording PAL60 ie colour system PAL but 525lines 60 fields and it worked. It did suffer from a few anomolies in the picture so I wouldn't call it high quality but it was colour and synchronised. Basically it the machines are not designed to record 525/60 but many can by virture of the playback compatibility.
    You will have to try a few makes.
  3. Guest
    Checkout Thomson VCRs, some of which can record PAL, NTSC, SECAM, and maybe PAL60
  4. Fartpants
    Fartpants
    I have not tried to record
    in PAL 60 on my Thomson, but in NTSC mode the tapes get used up much quicker (yep I know it is because they have to record the extra fields, thought I better point it out though).
