Can any scaling DVD players scale external sources?
Discussion in 'Projectors, Screens & Video Processors' started by jrecampbell, May 5, 2005.
  1. jrecampbell
    jrecampbell
    May 14, 2004
    56
    Have been having a trawl through the forums but one question I can't find a definitive answer to is which scaling DVD players allow you to also use them as standalone scalers for other sources. The only evidence I can find is a user of a Meridian player which seems to allow standard definition sources to connect to it and make use of its internal scaler independently. Do you know of any others? I'd love to just get one box - a scaling DVD player that also scales up my SKY+ for example. Would consider £500+ but suspect even up to a grand could be a pipedream, especially if the only option was a Meridian :rolleyes:
  2. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Only a handfull of high end machines to my knowledge, Including the TagMclaren DVD32R/FLR when fitted with PSM (although its not strictly scaling, just deinterlacing) :)
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    and the meridian isnt even that good......... £650 gets you an Iscan HD £800 an HD+ or Lumagen DVi both will outperfom scaling DVD players up to £2k but what are yopu connecting too that makes you want upscaled video anyway?
  4. jrecampbell
    jrecampbell
    May 14, 2004
    56
    Sky+, PS2 primarily. Probably overkill but the improvements I've seen from a friend's iScan with his Freeview box was quite remarkable. 2K not a sensible level of outlay for me but £600 seems reasonable'ish for a DVDO scaler seeing as it's going into a large Sharp LCD. Time to ponder some more I think.
  5. Carl Ed
    Carl Ed
    Mar 9, 2005
    54
    The Immersive Symmetry DVP does what you want, but it's highly debateable whether it has any advantages over just buying a DVD player and a scaler sepperately.
