ExtraMask
I want to create two subnets and wondering if it's possible with the diagram I've made.
The main router IP 10.0.0.1
CIDR Block 10.0.0.0/21
IP Range 10.0.0.0 - 10.0.3.255
Subnet 255.255.252.0
Within this there would be the servers, then PCs. The Mesh AP will have a Staff SSID that will have the same IP configuration as above.
There will also be a Guest SSID that will have a configuration of
CIDR Block 172.16.0.0/21
IP Range 172.16.0.0 - 172.16.7.255
Subnet 255.255.248.0
I want the PCs to be able to connect with all servers.
Staff SSID devices will be able to communicate with the servers and with the PCs and printers.
Guest SSID devices will only be able to communicate with the Guest Intranet Server.
Both SSIDs will have internet access.
I'm not sure if the design will work, I'm designing it for an assignment but the course material is pretty poor so I'm trying to learn from multiple sources.
