Can any media player output 4k?
Discussion in 'Video Streaming Boxes & Services' started by Mr_Wistles, Aug 27, 2013.
  1. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    12,109
    Essex
    +3,035
    I have just bought one of the new 4k displays. I know there is no official media yet but if I wanted to show some of the demonstrations and apple 2160p trailers is there a media player out there that can play it?
    I am currently using a WDTV Hub.
    Thanks.
  2. NX3
    NX3
    Dec 4, 2002
    3,493
    103
    +8
  3. MadScientist
    MadScientist
    Apr 30, 2006
    764
    46
    +103
  4. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    12,109
    Essex
    +3,035
  5. next010
    next010
    May 29, 2005
    10,764
    163
    +2,106
    For cheap boxes with 4k H.264 DRM free video;
    4K decoding and display support will be allegedly present in Amlogic M8 chipsets which power Android TV and linux/XBMC set top boxes, however that's a ways off probably the end of the year at most.
    4K decoding support is already present in Allwinner chipsets [another Android TV STB] but they don't do 4k display output so downscaled to 1080p.
    On a HTPC my info may be out of date but last I heard 4K support was not quite there yet in XBMC, it doesn't activate CPU multi-threaded decoding for 8-bit 4k video but does if it's 10-bit (GPU's cant decode 10-bit 4K video) so if your 4K media is 10-bit you need a strong CPU. Not entirely sure on GPU decoding 8-bit 4K video either in XBMC, seems it's suggested to stick to CPU decoding.
