Question Can an av receiver be modified to use a detachable power cable?
Discussion in 'AV Receivers & Amplifiers' started by jwall, Jul 3, 2015.
  1. jwall
    jwall
    Jul 3, 2015
    Pearl, MS
    I recently purchased the Onkyo TX-NR636 av receiver to run my surround sound setup. The power cable is not detachable.
    Is it possible to remove the cable and replace with one that is detachable? Are there any reasons not to? Where could I find a detachable power cable "kit" and what specs do I need to pay attention to?
    Thanks!
  2. dante01
    dante01
    Mar 5, 2009
    46,610
    +11,230
  3. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    "Why do you need a detachable cable?"
    Because fixed cables are horrid if you're removing the amp, you need to de-tangle and pull the cable though. Or if you're swapping amps round.
  4. dante01
    dante01
    Mar 5, 2009
    46,610
    +11,230
    Given the infrequency you'd ordinarily need to swop amplifiers then I'd not suggest it worth the effort. Most people leave their AV receiver connected to the same mains supply and in the same location for years on end. It would be easier for you to simply ensure the cables aren't allowed to get entangled than it would be to go to all the trouble of adapting your receiver. Plus the fact that this is only a feasible solution when dealing with another receiver or amp with the exact same cable inlet and the facility to accept a detachable power cable.
  5. simonlewis
    simonlewis
    Jul 31, 2014
    4,705
    stockport
    +1,757
  6. julk
    julk
    Jan 20, 2015
    33
    Dalkeith (nr. Edinburgh)
    +26
    +1 for this way to do it, except you should use a male IEC socket.
    Cheap, dead easy if you can wire a plug and lets you use a detachable power cable.
    The power cable has a female end (for safety) to plug into the male socket on the equipment.
    I have done it to most of my equipment which had a fixed power cable.
    • Agree Agree x 2
    • Like Like x 1
    • List
  7. themovierooms
    themovierooms
    Well-known Member AVForums Sponsor
    Aug 6, 2013
    1,011
    117
    Edinburgh
    +870
    I have seen it done but you will likley void any warranty if you encounter a problem.
