Can a samsung hd935 scale thru component ?
schillaci0
Established Member
Joined
Jan 18, 2005
Messages
821
Reaction score
22
Points
194
Location
Starting to get where I want to be
:hiya: have a 935 and was wondering can it upscale thru the component outputs once it is enabled for multi reg and hdcp is diabled. Any info greatly appreciated. :thumbsup:
Am not super technical with all this yet, however what I can tell you is that I had the 935 connected with component outputs and into my 4805 PJ.
When you have the Blue button (Prog Scan) enabled and the then use the button next to it you can switch between 480/576P, 720P and 1080i and do that over component.
Hope this helps.
Hi there guys
I took delivery of a pioneer 435 XDE screen on saturday and also purchased for evaluation a samsung 935 dvd player whichwas on sale as its discontinued for 160.00 € (roughly 110 GBP ) at present its connected via a cheap component lead, and dont know wether to keep it or not, althought it seemed cheap, but its slugish to respond on the remote comands sometimes the idea was for it to replace my Sony NS705 dvd/SACD player and in that respect its disapointing.
I was hoping to conect it to the screen via a DVI to HDMI cable and see how the picture quality fares, hopefully over the next couple days I will compare the 2 player for picture quality, but if it can upscale through the component lead this would make it more interesting to keep, but I could not see any evidence of the upscale via componet leads, as when I pressed the the DVI button the information th screen did not change and was showing 625 line on input 2 of my XDE.
Regards
Joe Rubido
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
