Can a laptop screen be used on it's own ?
Discussion in 'Desktop & Laptop Computers Forum' started by HMHB, Aug 3, 2006.
  1. HMHB
    HMHB
    Nov 11, 2001
    27,516
    Nottinghamshire
    +6,438
    I have a laptop which has reached the end of it's life, so I'm going to take the hard drive out to use elsewhere. Can the screen be used to connect to anything else ?
  2. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    Not without a lot of difficulty. Unlike PC monitors, a laptop screen is a dumb display panel, containing very little in the way of electronics. All the drive and interface components are in the laptop base.
  3. stevec46
    stevec46
    Nov 24, 2005
    192
    +3
    -But you might be able to sell it, either in this forum (but different section) or ebay.
    Steve
  4. miceri
    miceri
    Apr 8, 2006
    1,048
    Stockholm
    +59
    I read an article where some guy 'converted' the laptop so that it booted with absolute minimum drivers etc into a powerpoint show stored on a memory card (In an adaptor in the PCMIA slot).
    He then separated the screen from the main body. The screen was then mounted in a picture frame (with a larger depth than normal, a viewing case I think...) and a cable, hidden or not, was connected back to the laptop body.
    It was then possible to have a slide show running of your favourite paintings / holiday snaps mounted in a frame on the wall / coffee table.
    Pretty cool. I was gonna do this myself with an old laptop. But I'm clinically lazy so gave up in the end.
    Google 'picture frame laptop' quite a few hits actually.
    This is one: http://www.popsci.com/popsci/how20/a4a95adebbf6a010vgnvcm1000004eecbccdrcrd.html
  5. HMHB
    HMHB
    Nov 11, 2001
    27,516
    Nottinghamshire
    +6,438
    Some ideas there, thanks chaps :)
    Mind you, having said that:-
    The battery never holds a charge so it always has to be plugged in
    The dvd/cd drive is never detected so doesn't work
    If you place it flat on the desktop it reboots after a few minutes due to the heat so has to be propped up on something
    It only has 256MB RAM and a P3 processor and is unusable with XP
    I've used the hard drive for something else so the only thing on this laptop in reasonable working order now is the screen
