Can a GR-D23 capture analogue to DV tape?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by TonyM19, Dec 26, 2004.
  1. TonyM19
    TonyM19
    Feb 28, 2004
    72
    I’m considering buying a GR-D23 camcorder. I appreciate that here are probably better ones about but budget is an issue.
    The clincher would be if I could use it to transfer analogue to digital. According to the specs I’ve read, the GR-D23 has Video in/out and DV out (but no DV in). Does this mean that I could connect my VCR to the camcorder and save analogue to DV tape? Could I do the same with my old Samsung analogue camcorder?
    I’ve read that some camcorders can convert analogue to digital without recording to DV tape. Can the GR-D23? If not, how can you tell by looking at the specs?
    What benefit would I get from DV in? If it’s a real issue I’ll go back to the drawing board.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    If a camcorder does not have DV-in then it will not have AV-in. AV-in is the feature you need to be able to connect an analogue device such as your VCR to the cam.
    Many cams with DV-in will still not have AV-in so you need to check the specs closely to make sure it has the features you require.
    Mark.
  3. TonyM19
    TonyM19
    Feb 28, 2004
    72
    Thanks for the quick response.
    The search continues :)
