Can a Domino 18/20 be used with a 9ft throw?
Discussion in 'Projectors, Screens & Video Processors' started by Timmy C, Oct 21, 2005.
  1. Timmy C
    Timmy C
    Oct 10, 2003
    5,702
    +592
    This is a question for Jeff really but if anyone else knows for sure then feel free to reply. A mate of mine is considering the idea of a projector since reading all the rave reviews of the recent Sanyo and Panasonic LCD's but I can't help thinking you could pick up a used Domino with the same sort of cash which I would have thought was a better option.
    Anyway, he's only got a maximum 9ft throw which goes off the scale on the projector central throw distance calculator. Does this mean it can't be used at such a short distance without picture problems or does it just mean a small image? If it can be used then what size image are we talking?
    Out of interest has anyone ever compared a Domino 18 or 20 with a Sanyo Z3/Z4 or the Panasonic equivelents?
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Tim
    A 9 foot throw will give you a 49" wide picture which is bigger than a 50" (diagonal) plasma and a lot cheaper and arguably better picture quality.
    That may seem like a small picture but if you are only sitting say 8ft away it will be big enough.
    Jeff
  3. Timmy C
    Timmy C
    Oct 10, 2003
    5,702
    +592
    Thanks Jeff. I'll pass on the info.
