Can a BT Home Hub turn off my TV?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Bettingmad, Jan 17, 2008.
  1. Bettingmad
    Bettingmad
    Dec 31, 2003
    40
    Yorkshire
    I have Wharfedale 1710AF connected to a Sky digibox and the TV keeps blacking out and going into standby mode.
    I have tried connecting it via just scart or just aerial lead from the sky box but either way it keeps turning off.
    If I connect 2 TV's at the same time to the sky box only the Wharfedale knocks off.
    If I move the wharfedale to another room and connect it to a Freeview aerial it stays on.
    The only thing I can think is that in the original room the BT Home Hub is doing something to the TV. The wireless channel used on the home hub is 1 but if I change it to say 7 the TV keeps knocking off. I've had the same Sky digibox for years so assume that can't be the problem.
    Any ideas?
  2. JayCee
    JayCee
    Jan 20, 2004
    23,631
    Lanarkshire
    +2,551
    And if it's on any other channel but 7...does it still cut off?
  3. Bettingmad
    Bettingmad
    Dec 31, 2003
    40
    Yorkshire
    I only tried channel 7.
    Since then I have disconnected and powered everything down. Separated them about a bit, reconnected everything and for the last couple of hours the TV hasn't switched off so I might be OK now.
