Can a 5.1 be converted to 6.1?
Discussion in 'AV Receivers & Amplifiers' started by Chevy91z, Oct 21, 2003.
  1. Chevy91z
    Chevy91z
    I have been reading some threads and there seems to be some real good advice in these forums.. What I was wondering is Can my Yamaha receiver be converted to a 6.1 or 7.1 reciever? Where it will need a seperate decoder and where can I find one if it is made? I have been going crazy trying to find information on this and no one could help me. Any advice would be appreiciated. O and Just buying a new receiver is a little to obvious so dont bother telling me that. Again thanks for any help in advance.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    To get 6.1/7.1 your receiver needs to be able to decode the newer ES/EX formats & you need to have 6 or 7 channels of amplification.
    I would guess that as you say your receiver is 5.1 it will only have 5 amp channels & if it does it will therefore not decode 6.1 disks as 6.1. Therefore I would think your only real option is to get a new receiver. Some receivers can decode the new formats but only have 5 channel amps but will have pre-outs to feed external amps. Look for the ES/EX symbols to see if you can decode them. If it just has DD/DTS then it will only be 5.1
    You can buy a separate processor and amps but these tend to be high(er) end equipment that cost a lot more money than a new 7.1 receiver.
    Mark.
  3. Jase
    Jase
    Mar 16, 2001
    9,532
    UK
    +932
    Sometimes the most obvious is the correct answer.;) But I won't bother telling you that.:D
  4. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    I agree with Jase here.
    Yamaha have 8.1 compatible amp/recievers for less than 300.00, adding an external EX/ES processor of which i am aware of only two is just as costly and does not allow time alignment and break-down to center back channel.
    Steven
  5. avanzato
    avanzato
    Jan 21, 2003
    1,881
    Norfolk
    +61
    Could you do it by connecting a prologic processor/amp to the rear pre-outs?
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    I doubt it as you would only have the pre-outs for 5.1, therefore the surround rears would be exactly the same output as the side surrounds. This would not therefore be 7.1
    Mark.
  7. avanzato
    avanzato
    Jan 21, 2003
    1,881
    Norfolk
    +61
    I've thought it through now :)
    The processor/amp connected to the rear preouts. The centre channel of the processor/amp is the centre rear and the L/R surrounds are the L/R front outputs of the processor/amp. A processor will need an additional power amp for the front channels (now surrounds). Academic interest only as it'll be a whole lot easier and cheaper to buy a new amp.
  8. Chevy91z
    Chevy91z
    Thanks all, I figured as much but I was hopeing there might be a cheaper solution to do it. O well, It took another country for me to get the correct answer and I really appreciate the help. So new receiver time for me, Yamaha here I come again. O By the way, if anyone needs something shipped from the U.S. I'll be glad to help you out as a thanks.
