Camera stand
Discussion in 'Photography Forums' started by deekay, Nov 4, 2004.
  1. deekay
    deekay
    Hi people
    The bolt that fits into cameras is a 1/4inch diameter (6mm) by a 20 threads to the inch and is known as a 1/4 -20 bolt and is fitted on tripods, camera brackets, camera mounting plates etc.,
    I'm planning to make an adjustable camera stand for macro photography and need such a 1/4 - 20 bolt or mounting plate with a bolt on it.
    Does anyone have a mounting plate, bracket, lighting bracket or even the bolt on it's own about 50mm long they can sell me please? Or know where I can get one at a low cost?
    Regards,
    deekay
  2. Brian110507
    Brian110507
    The bolt on it's own should present no problem at all to you - it is a standard 1/4" Whitworth bolt (Don't try to metricate it - it isn't metric) and while you may not find any at your B&Q or Homebase any GOOD hardware store should have/should be able to get some for you. If you really are stuck PM me your address and I'll put one in the post to you.
  3. deekay
    deekay
    Thank you Beejaycee
    There is a good iromonger near me I'll see what he can do
    Regards
    deekay
