Camera Settings Help
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by section33, Aug 25, 2006.
  1. section33
    section33
    Hi ya 1st post here… anyway I need some help. I have a Canon MVX200i, however my camera doesn’t have a manual in English (and learning another language isnt an option) and I’m trying to set it up to film in 16:9 (or something close to letterbox format) so I need a sort of quick step by step. Got to start filming for a project tomorrow and I need to get it sorts, many thanks in advance
    Gary
  2. toadoftoadhall
    toadoftoadhall
    May 10, 2002
    363
    Worcester uk
    +23
  3. bsuttie
    bsuttie
    Apr 4, 2006
    1,545
    63
    Edinburgh
    +206
    Manual for that camera is available here
    Looks like to go to 16:9 mode go to the Camera Menu, Camera Setup, 16:9 and turn to ON.
    Note that this is "True 16:9" mode i.e. 16:9 full height anamorphic, not letterboxed.
    If you really want letterboxed you should either shoot 4:3 and mask, or shoot 16:9 FHA and squeeze.
    However for most uses nowadays, and particularly if you are going to end up on DVD, you would be better keeping it 16:9.
    In either case you should shoot some test material and choose whichever workflow gives you the best quality (i.e. does resizing in the camera look better or worse than resizing in software)
    regards
    Brian
