camera care
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by kayak2sg, Aug 31, 2005.
  1. kayak2sg
    kayak2sg
    hi,
    on the subject of camera care can anyone tell me how often i should subject my cam to a tape head cleaner and for how long?
    quick silly one!
    does using my cam as a deck for editing through pc, involve head use and abuse?
  2. Roy Mallard
    Roy Mallard
    You should really let the camera tell you when it detects dirty heads, tape cleaners should be played for a 10 second burst, no more.
    Yes, using your cam as a deck will invlve more wear, but given that decks start at £700, then it isn't really a choice for most home users.
  3. kayak2sg
    kayak2sg
    thanks again roy,
    only 10secs, wow that was a close one!!
    regards,
    2sg.
