Camcorder User review of JVC GR DVX25
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by NAU, Dec 8, 2003.
  1. NAU
    NAU
    I'm confused - not an unusual thing !
    I'm looking for a cheap-ish DV camcorder, got to be fairly small and its got to have DV-in, otherwise I'm fairly open to specs etc.
    I picked up a couple magazines from Smiths on Saturday and lo and behold there's a review of a DVX25 model - and it looks just perfect. However when I try to find one on the web all I can find is a DX25 which doesn't seem to have DV-in.
    Has Camcorder User messed up? Or is this a new model? Or indeed an old one?
    (Incidentally What Camcorder also reviews a DX25 which deffo doesn't have DV-in!)
  2. virgola
    virgola
    GR-DX 25 seems infact to only have DV OUT
    According to my sources JVC GR-DX35 HAS DVin/out
  3. Brian110507
    Brian110507
    A search on the JVC website ( www.jvc.co.uk ) returns NO information on a GR-DVX25 it doesn't exist on the JVC website, the only model featured on the JVC website is the GR-DX25 which only has DV-out.
    As you say in the review of the Camcorder in Camcorder user it does say DV-in/out but in the specifications published at the back of the magazine it now says DV-out only. so they are not consistant in the one magazine.
    Also in the magazine is an advert for www.letsgodigital.co.uk where they are offering a GR-DVX25 but do not give a specification, however if you visit that website you get nothing if you search for DVX25 but can find a DX25 which is DV-out only.
    It seems that somebody at JVC is doing their very best to throw confusion all around.
  4. virgola
    virgola
  5. NAU
    NAU
    Thx for the help - I think I'll give up on this one, as I suspect its a messup at the magazine.
  6. Brian110507
    Brian110507
    Wouldn't be the first one
  7. Frenchie
    Frenchie
    I think that in the UK, you have:
    - JVC GR-DX25EK: DV Out only, WITHOUT SD Card
    - JVC GR-DX95EK: DV Out & DV In, WITH SD Card
  8. Frenchie
    Frenchie
    I found the JVC GR-DX25EK: DV Out only, WITHOUT SD Card for £322.50 at www.pantheronline.co.uk where you can buy directly in store.
    You won't find a cheaper compact camcorder.
    Zoom (optical) is 16X.
