Camcorder to PC cables / editing software question
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by focus_driver, May 4, 2007.
  1. focus_driver
    focus_driver
    Dec 21, 2006
    3
    I've just bought a new Panasonic NV-GS80EB-S [minidv] camcorder and had it delivered to my address in the UK. However, it's not supplied with a cable to connect to a pc or any software. So what cable do I need to buy [I'm abroad for the next 5 weeks and need to have the cable arrive before I get back to the UK, so I can't read the instruction manual!]
    And what video editing software is about? What are the good programs, and are there any freeware ones. I don't mind paying if I need to.
    Thanks guys and gals.
  2. sassan22
    sassan22
    You would need a firewire cable 4 pin to 4 pin or 4 pin to 6 pin. Depending on your computer. If you use a laptop, then most likely the 4 pin to 4 pin would be right. Regarding the software, I would suggest Sony Vegas. You can download a trial version and use it for 30 days. If you like it, then you can buy it online.
    Sassan
  3. jaymac
    jaymac
    Jan 15, 2003
    1,726
    63
    North Somerset
    +138
    You can do basic editing with windows movie maker which you have if you have XP . Other than that there are several software editors you can download the one already mentioned or adobe premiere elements . Ulead movie studio, Magix movie editor all do much the same some easier to use than others some better or dearer/cheaper. .Its something you have to suck and see as we are all a bit biased towards our own
  4. felix2
    felix2
    Jun 21, 2005
    457
    28
    Felixstowe
    +40
    See the list here. Good luck! :)
