phaetongraph
What HD camcorders have manual control over focus and shutter speed please?
Phaeton.
Phaeton.
Quite a lot have manual focus but without a focus ring the best you'll get is touch focus where you touch the screen to select what you want to look sharp. It's almost impossible to do without juddering the camera. My Samsung R10 has shutter speed but if you change it the aperture goes into automatic an vice versa. I don't think there was any way I could've found out about that before I bought it.
Many thanks,
I have a Canon MV830i which does everything I need: manual focus, manual shutter speed (select and fix), even manual White Balance if you need it, but technology must have moved on a bit since this cam was new and I want something with a higher / sharper definition.
But unless it has those manual features it won't fit the bill: I bought a Sony Handicam a while ago and it was full auto, I had no control over it at all.
Thanks again
Phaeton.
Take a look at the Panasonic 900 (or cheaper 800) series, has manual controls.
Regards
Phil
Regards
Phil
Do the camcorders in this range film exclusively in 16:9 format or can 4:3 be selected please?
Thanks again,
Phaeton.
As they only shoot HD they are in 16:9. You will not find an HD consumer camcorder that will shoot 4:3 anymore.
You could of course shoot as though it were 4:3 then crop the ends off in an editing package then convert to SD or pillar box it for HD which is always 16:9.
Why do you want to shoot 4:3, that format is pretty much long gone, certainly in the context of HD?
Regards
Phil
Thanks Phil,
I have loads of old analogue home movies I want to transfer, all in glorious 4:3
What's the sharpest, finest dv format I could use that earlier 4:3 cams would carry, the equivalent of SVHS to standard VHS quality in other words?
Best regards,
Phaeton
An HD camcorder would capture those just fine, with more resolution than DV but they would be pillar boxed on playback, but that would be the case with any 4:3 material no matter how captured.
Regards
Phil
Thanks Phil,
