Camcorder connection
Ian Carter
Established Member
Joined
Apr 4, 2002
Messages
763
Reaction score
3
Points
182
Location
Swindon, Wilts
The 3 phono lead, White, Red & Yellow I have to connect the camcorder to the TV is a bit dodgy. Can I use a normal pair of red/white phonos and a single phono as well in the short term? Or is the yellow lead completely different? I know the yellow lead is the video connection, but perhaps a normal lead would do.
Are you after or a 3 phono to 3 phono lead? If so then you can get one of These. The yellow composite video lead is different to the red/white leads that are used for audio, but as a temporary thing you could get away with standard phono leads.
Most camcorders don't have the 3 phono sockets, but a small jack socket instead. If this is what is required then you should be able to get one from the above site.
Mark.
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
