camcorder connection blues
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by ben2579, Apr 14, 2005.
  1. ben2579
    ben2579
    Apr 13, 2005
    483
    +12
    hello there,
    please could some one help me with my troubles.
    I am trying to connect my sony DV camcorder to my PC via firewire. the computer recognises the camcorder when connected however i am unable to capture any picture.
    i have had the firewire card checked and its ok.
    i have tried various software.
    i have only tried the firewire cable that came with the card, someone mentioned that sony requires a special wire sometimes? any truth in this.
    any ideas help??
    ben
  2. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
    Please give us some more information. What software have you been trying and what is the exact problem/error you are getting.
    If your PC is seeing the camcorder then I would think that the cable is fine.
    DigiStuff
  3. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    Don't know where you heard about Sony requiring a special wire from. A firewire cable is a firewire cable. The only differences are that sometimes you need a 4pin to 6pin wire, and others you need a 4pin to 4pin depending on what you're plugging it into.
    As DigiStuff says, I think we need a bit more information before we can fully help.
    Just a few initial thoughts however.
    1. Have you made sure that the Camcorder is in VCR mode?
    2. Normally the software is (or can be) set to control the camcorder so that it starts it when capture commences. Check that this is the case, otherwise you'll need to manually press play on the camcorder.
    3. Make sure the camcorder is connected and turned on before you start your editing application.
    Hope this helps.
  4. ben2579
    ben2579
    Apr 13, 2005
    483
    +12
    guys,
    thanks for the help so far, will try those basiscs and get you full details of the problem asap.
    cheers ben
  5. Slipperystevens
    Slipperystevens
    Jan 2, 2003
    264
    Berks
    +14
    I'm just starting to dip my toe into the video editing area. However, I have used a free piece of capture software called WinDV which can be found at http://windv.mourek.cz/
    This software only captures the video output from your camera and doesn't do any editing etc. but it will confirm that your connection is OK.
    Hope this is of some use to you.
  6. ben2579
    ben2579
    Apr 13, 2005
    483
    +12
    just to clarify the problem, the camera (sony DV DCRPC5 (2000 model) connects to the computer and it is recognised. the computer controls the camera, but when it plays no picture or audio is captured. when recording the camera plays but the computer counter does not start.
    when stopped it asks where to save the file. when i go back to play back this file a message appears "an error occured while opeing this file. either the selected file is not a windows movie maker project file or the project file is corrupted"
    this is obviously with windows movie maker but i have also tried pinnacle studio V8
    the camera was on and connected b4 the computer was started. the camera was in playback mode.
    thankyou for the suggestions so far but i am still a bit lost
  7. ben2579
    ben2579
    Apr 13, 2005
    483
    +12
    still struggling with the above problem, is there anyone with experience of sony camcorders that could help thru some light on the problem.
    ben
