Camcorder Cannon MV940
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by vickip, Aug 2, 2006.
  1. vickip
    vickip
    Jul 25, 2006
    22
    I need some help guys.
    I brought a Cannon MV940 a couple of weeks ago and I have a problem. I done a little bit of filming and thought I would load it onto my computer via it's USB cable but guess what! I can't get the video through and my computer is not recognising the new hardward. I loaded on all the software that has been supplied and it just doesn't work.
    Any suggestions.
    :confused:
    Vickip
  2. biggy7
    biggy7
    Jan 10, 2002
    2,540
    83
    Manchester
    +189
    have you tried firewire connection mate?
    its what everyone uses to transfer video from camcorder to PC!
    you will need a 4pin to 6pin one, about £1.50 from ebuyer.com
    you need a firewire connection on your PC though
  3. clokan
    clokan
    biggy7 is right, you need to use firewire, the usb connection on you camera can only be used to transfer data from the digital card (SD I think), it does work for DV
  4. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Yep, I have a canon and USB is for photos only
