Camcorder AV output
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by hornydragon, Jan 11, 2002.
  1. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Does it matter whether I connect the Black audio lead out of my CCD-TRV78E to the red or white input on the scart adapter, Is there any point in using s-video to transfer Hi8 to VHS usinh 4 head Nicam VCR?
    Cheers? :D
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    In most cases the sound will just go to either the left or right hi-fi audio track and the mono linear audio track. The remaining hi-fi track will be silent. If you play the VHS back on a stereo TV using the scart connection you may find the sound comes from just one side.
    No. Only S-VHS recorders are able to accept a signal via the S part of a SCART lead. Ordinary VHS machines (including NICAM) only use the composite connection for picture.
    Hope this helps.
