Cambrige Audio M1 and Angel ?!
Discussion in 'Home Cinema Control & Remote Controls' started by filipe, Sep 26, 2001.
  1. filipe
    filipe
    I just saw in what hi-fi mag a remote control called Angel which looks identical to the cambrige audio M1, except the name printed on it.
    Are they really the same?<br />Richer Sounds also have a sony one (blue LCD touchscreen and butons, is it better or worse than the CA?<br />Cheers<br />Fil
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
  3. burkey
    burkey
    About one year ago I purchased the cambridge audio remote from richer sounds . It is the same as the angel but with another name . I would not recomend you buy either of them . After owning mine for just over a year rhe remote lost all of its memory, all my had work lost . I have spoken to various retail outlets who have heard of the same problem with this remote .I now own a phillips pronto which can be obtained for £140 on various web sites . This control is the business and has far more scope especially when linked up to a PC . Save a few extra pounds and get the pronto ??&gt;
  4. KAO
    KAO
    I used to own an Angel and I found it very useful. However, you can't rename any of the 'buttons' on screen and I found it didn't have a very good IR range. It's not a patch on the Pronto (but then it's not intended to be).
    [ 28-09-2001: Message edited by: Keith ]</p>
