Cambridge M1
Discussion in 'Home Cinema Control & Remote Controls' started by Brox, Aug 11, 2002.
  1. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Recently bought the cambridge audio M1 clone from Maplins called the e-pilot, I like it a lot - very easy to setup, nice design only slight downside is you sometimes can't always program all buttons from the remote, but there are enough for the most used functions certainly good enough for me.
    However I cannot get it to program my Harman Kardon AVR500, it takes 1 or 2 of the buttons - but either fails to learn them or seems to learn them but they then do not work
    Any ideas?
    If I can't get it to work it'll have to go back.
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    If it don't work first time, it won't work second time, or third, and so on... Take it back if you ain't happy.
  3. mjn
    mjn
    May 24, 2001
    22,723
    Herts, England
    +10,867
    try new batteries in the HK remote, i had this problem with my M1. The learning eye is quite weak.
