Cambridge Azur 351R IR Codes not working?
NdG1977
Hi everybody,
I just bought a Cambridge Audio 351R, long story sort no remote and without it I cannot bring up the OSD for the setup.
I have a phone with IR Blaster, I downloaded a bunch of apps hoping to find the model and remote simulator with no luck, I can get some controls to work like power and volume, but no OSD.
I also got the document with the codes from the Cambridge website. Link
I managed to get the controls in the 2nd table to work with IR Remote Creator, but no luck with the ones in the first table! They are in the same format so I'm pretty sure I'm doing it right...
Would you suggest to try another app? Anything I'm missing?
Any suggestion wellcome!
