NeilH said:I use Spotify quite a lot and couldn't be bothered with the hassle of connecting/disconnecting.
Also, I use the MacBook for pretty much everything and wouldn't want it tied up
being connected to the amp.
Similarly, Bluetooth is out as I don't really use anything with Bluetooth for music.
Any thoughts on a similar device that supports Spotify?
The problem is that as far as I know, nothing other than Sonos or the SBT has a Spotify plugin. Spotify isn't very easy to integrate and as such anything sold in less than olympic quantities hasn't done so.
I asked why the Magic 6 didn't come with Spotify built in and was told that the cost of the licence would be prohibitively expensive for such a small company.
Oh well, back to the drawing board.![]()
-spec the bluetooth module on the Stream Magic 6 and use your phone
on the occasions you wanted to use Spotify?
Yep, Spotify keeps a tight grip on the encryption they use on the stream. IIRC the Squeezebox applet was co-developed with Spotify who supplied a binary for their secret-sauce.
OP, if you are just after Spotify, how about a 2nd hand iPod Touch with Spotify app in a dock?
NeilH said:At the risk of contradicting my earlier answer (and because I'm running out of ideas!), what do you think the sound quality of that would be like running from the Macbook?
The Cambridge asynchronous USB implementation is very good- it should be at least as good as a plug in and probably easier to search too.
