Cambridge Audio x300
Discussion in 'Subwoofers' started by mrmoofo, Mar 10, 2013.
  1. mrmoofo
    mrmoofo
    Oct 25, 2009
    17
    Nr Zurich
    This is hooked up to an Arcam AVR 280
    With minx satellite speakers - everything is great. I love the product and my wife loves the size ...
    But the sub has stop working - it got a bit flaky - but now nothing, nada. This happened last night
    The amp tells me that a sub is connected
    The sub (which has and auto on) switches itself one, and the little light at the back comes on
    But no sound , no rumbling at all - even a full volume.
    The connections are all correct
    Do I have a FUBARed sub??
    Any thoughts?
  2. Tom @ PSA
    Tom @ PSA
    Well-known Member AVForums Sponsor
    Apr 12, 2012
    879
    96
    +854
    Take the easy-to-eliminate variables out of the equation.
    1)replace the sub cable with something else(any old composite cable for example). I know if the auto-on led lites the cable should be ok....but take the 30 seconds and swap it.
    2)set the sub to always on/on.
    3)in the receiver speaker menu be sure you have all speakers set to small.
    Try the receiver calibration sequence...when the sub test tone plays...anything?
    Tom V.
  3. mrmoofo
    mrmoofo
    Oct 25, 2009
    17
    Nr Zurich
    I will check the leads this w/e when I am back
    and do the test tone thing
    Richer Sound tell me there is a two year warranty so it will be repaired / replaced FOC - as long as it is not an amp issue!
