Cambridge Audio or Yamaha ?
Discussion in 'AV Receivers & Amplifiers' started by RedDucati, May 8, 2007.
Tags:
  1. RedDucati
    RedDucati
    I just can't decide - which of these two receivers, CA 540R or Yamaha V661, should I buy ? Cambridge produces decent sound (I'm going to listen to 2.0 audio a lot as well), but on the other hand, Yammy has a few features which may be useful, such as YPAO, HDMI I/O, programmable remote control.
    And Yamaha 6 series is said to perform well too.
    The prices are similar.
    Can you help me to choose ?
    Thanks,
    RD
  2. bu5ter
    bu5ter
    Oct 17, 2004
    2,166
    63
    Egham
    +116
    If its any help i auditioned a CA 540R against a Yammy 759SE and went for the yamaha its a much better finished product and i preferred the sound the cambridge sounded a bit harsh for my ears!!
  3. alphabet
    alphabet
    Having owned a number of Yamahas, I would say you will have to choose between these features:
    Yamaha:
    Lots of DSPs
    Very good in HT
    YPAO(and all the other bells and whistles)
    Power delivery does not match claimed specifications
    Mediocre in Stereo
    and
    CA 540R:
    Great in stereo
    Good in HT
    Power delivery on par with specifications
    Zero bells and whistles
  4. RedDucati
    RedDucati
    Yep, all those pros and cons make me torn :) Still...
  5. schnuffi
    schnuffi
    Jun 16, 2006
    98
    +5
    It's never easy deciding. I've not heard the Yammy but can just say I am very pleased with my 540R v2. It has bags of punch and you really don't need lots of "features". It's really easy to set up and remember the sound is the important factor :thumbsup: and that can only be decided by you. Mind you I have never heard mine in stereo as I use an integrated for driving the fronts.
  6. alphabet
    alphabet
    Unfortunately you have to decide if you need all the extras and also which of the two sounds best to your ears:)
