Cambridge Audio or Roksan....?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by lcd4ever, Jun 11, 2009.
  1. lcd4ever
    lcd4ever
    Mar 24, 2009
    147
    Fife, Scotland
    +20
    Going to add a stereo amp via the preouts of my Yamaha receiver into my system....
    Sources are Nad C545BEE cd player and Linn Axis turntable...
    Front speakers are MS Mezzo 6 floorstanders....
    Think I've narrowed it down to 2 either the new Roksan Kandy K2 or the Cambridge Audio Azur 840A V2 opinions please......??????
    Or am I missing something else in the sub £1000 class ?
    Bear in mind if the wife can't hear an improvement over the Yamaha RX-V1900 I could be getting divorced lol
  2. Matt W
    Matt W
    Dec 3, 2008
    286
    28
    Aberystwyth
    +44
    Get a stereo Power Amp? Use the Pre-Amp in you Yamaha, allows you to get more for your money IMO.
  3. durk
    durk
    Jun 19, 2005
    616
    Shrewsbury
    +31
    The cyrus amps have unity gain as does the audiolab s8000 and i belive the rega mira also does! Go and demo, i did and bought the CA 840 but in fairness i didnt listen to the rega.
    Im of the opininion that your better using and intergrated with unity gain as the pre amps tend to much better in the dedicated stereo amps but a power amp is more straight forward and woulds still give you better preformance
  4. phil t
    phil t
    Jun 3, 2007
    2,154
    Hook, Chessington, Surrey
    +308
    :devil:
  5. phil t
    phil t
    Jun 3, 2007
    2,154
    +308
    Buy the CA and take it along to the Roskan audition, buy or return as suits your ears?
  6. trailer
    trailer
    Dec 22, 2004
    2,880
    +231
    Get a decent stereo amp with a unity gain as mentioned (and a decent phono stage).
    I really don't think you are getting the best out of your Linn and CD putting them through the Yamaha.
    If you use the Yamaha for AV then the unity gain through the stereo amp will improve your sound too.
  7. phil t
    phil t
    Jun 3, 2007
    2,154
    +308
    A piece of wire has unity gain. An amp with the gain of unity will be like a piece of wire.
    Unless "Unity Gain" has gained another meaning, what is the point of buying a unity gain amp?
  8. trailer
    trailer
    Dec 22, 2004
    2,880
    +231
    *Unity Gain* is where the input to the stereo amp (usually using the AV input) by passes its own volume control. This means when listening to the AV amp you can use the stereo amp for the front left and right and set the volume levels for the speakers using the AV amp. It saves adjusting the volume on the stereo amp every time you switch sources.
    :suicide:
  9. phil t
    phil t
    Jun 3, 2007
    2,154
    +308
    Ah, I see. So bypass the pre-amp section of an integrated. Not really unity gain though.
    :devil:
    wikipedia Gain
    Sound Glossary
    :devil:
  10. trailer
    trailer
    Dec 22, 2004
    2,880
    +231
    Your first link doesn't even mention unity gain.
    The second link explains it perfectly.
  11. phil t
    phil t
    Jun 3, 2007
    2,154
    +308
    At the bottom, last line of text.
    :suicide:
    I understand that an amp can have an AV/HT direct which bypasses its volume control, but when used like this the amp doesn't have unity gain, it has the gain of its power amp section.
    :devil:
  12. trailer
    trailer
    Dec 22, 2004
    2,880
    +231
    moving on......................
  13. lcd4ever
    lcd4ever
    Mar 24, 2009
    147
    Fife, Scotland
    +20
    Durk di you demo the Kandy amp with your cd player and then decide on the CA ? If so can you tell me why....
  14. MilkyJoe
    MilkyJoe
    Jul 5, 2006
    237
    28
    +27
    Why is the K2 better than the 840A?
  15. durk
    durk
    Jun 19, 2005
    616
    Shrewsbury
    +31
    yes i did:)
  16. scorpion88
    scorpion88
    Aug 10, 2008
    1,985
    63
    Cardiff
    +179
    Presumably the CA will work better for you then in your system. Good choice old chap.
